Thread: Cherry Picker Mod
    Viny's Tools
    Cherry Picker Mod
    So, I had this old cherry picker, (engine hoist?) that I wasn't really using in the barn. It was just taking up space. Since I converted the front of my tractor to a skid steer setup, I thought I'd mod the cherry picker to use as a crane on the front of the tractor. I mounted the plate to the back of the cherry picker and shortened the front outer legs to use as framework for the plate. I don't expect to lift anything too heavy, but caution will be observed...!
    Here you see it mounted on the tractor:
    Here it is raised. That is about 15'!
    I will probably look into replacing the manual cylinder with a hydraulic one as I have remotes in the front of the tractor...
  2. The Following 4 Users Say Thank You to Viny For This Useful Post:
    Captn Roy (Aug 2, 2018), Jon (May 2, 2018), PJs (May 2, 2018), Seedtick (May 2, 2018)
    Thanks Viny! We've added your Cherry Picker Modification to our Cranes category,
    as well as to your builder page: Viny's Homemade Tools. Your receipt:
