looks like it works great for a blace designed fo cutting paneling but I wonder how well it would work for blades with set in them for cross cut
As I stated previously I ground tools for 17 years and in the first 4 years or so we were using what was called Semi-high speed steel blades. Thes blades did have a set put on them. How we did it was set the teeth before grinding giving a bit more than needed and for copper and aluminum we just ground them enough to clean them up straight across the top. On the blades that were needed to cross-cut wood the machine was set for half the number of teeth thus grinding every other tooth, and the wheel was either dropped or raised a certain amount to give the alternate bevel grind. After one side was done the blade would be indexed to start on a tooth of the other side. Most of the blades we ground were 12 to 14 inches in diameter.
emu roo (Jan 17, 2026), PJs (Nov 26, 2018), Toolmaker51 (Nov 24, 2018), Wildwilly (Mar 19, 2022)
