Results 1 to 6 of 6
Thread: Cleaning a chimney with a blower - GIF
    May 2024
    nova_robotics (Dec 7, 2025)
    It seems they will tic-tok anything to make people think things are good ideas without any explanations.
    The only thing using an exhaust fan on top of a chimney will do is draw out the loose ash layer the creosote buildup cannot be removed this way. Creosote buildup is what causes chimney fires and must be removed by other means, like swabbing with a chimney brush. However, a powerful enough suction fan may help to clean the dead air insulation cavities of double and triple pipe chimneys or be considered as a final stage for chimney cleaning after creosote swabbing. Or a way to drive the greanies insane when they see the ash cloud
  4. The Following 4 Users Say Thank You to Frank S For This Useful Post:
    Duke_of_URL (Dec 9, 2025), emu roo (Dec 7, 2025), nova_robotics (Dec 7, 2025), piper184 (Dec 7, 2025)
    bruce.desertrat's Tools
    Or the downwind neighbors with laundry on the line...
  6. The Following 3 Users Say Thank You to bruce.desertrat For This Useful Post:
    Duke_of_URL (Dec 9, 2025), emu roo (Dec 7, 2025), Floradawg (Dec 8, 2025)
    Supporting Member thevillageinn's Avatar
    Jul 2017
    thevillageinn's Tools
    Also, since this is a video - and videos only show what the creator chooses to show - this clip does not necessarily convey the entire process used here.
  8. The Following User Says Thank You to thevillageinn For This Useful Post:
    Sep 2018
    nova_robotics's Tools
    Yup. I've cleaned chimneys before. No way that stuff is coming out with a fan. It's like the inside of your chimney grew a layer of tree bark. It isn't moving from airflow. You need to mechanically remove it.
  10. The Following User Says Thank You to nova_robotics For This Useful Post:
    Frank S (Dec 7, 2025)
  11. #6
    May 2015
    Tasmania, Australia
    Bony's Tools
    (Attempting to) clean a chimney with a sucker, rather than a blower may be a more appropriate heading.
    No consideration for the neighbours!
