Thread: Clutch push rod modification (for classic bikes)
    olderdan's Tools
    As anyone with a classic motorcycle knows achieving a smooth clutch action is difficult, this is not always due to the clutch itself even when set up correctly but more to do with the pushrod actuation.
    The gearbox main shaft has a gun drilled bore which is left as a drilled finish, when pressure is applied to the ends of the push rod it will bend and rubs in the rough bore surface resulting in a sticky or jerky action, close inspection of a used one will confirm that this has been happening as there will be score marks on the rod.
    Fortunately there is a simple remedy as written by Don Morley of trials fame in an article which can be found on Hitchcocks website. Hitchcocks Motorcycles - Technical Notes under article 5, the cut ends should be hardened and polished and as this is usually drill rod it is easily done.
    I can testify that this mod makes an enormous difference to the feel of the clutch lever, the weight is still the same but the action is nicely smooth and I now do this mod on any classic that I work on.
    Clutch push rod modification (for classic bikes)-screen-shot-12-23-17-05.55-pm.png
  2. The Following 5 Users Say Thank You to olderdan For This Useful Post:
    KickStart (Dec 25, 2017), pennswoodsed (Dec 29, 2017), Seedtick (Dec 24, 2017), tonyfoale (Dec 26, 2017), Toolmaker51 (Dec 25, 2017)
    Jan 2017
    NOLA
    That's a cool website you shared.
    I've used that trick at various times on different bikes. I have American V-Twins (60's-90's custom & stock) & British Twins (60's & 70's custom & stock, mostly Norton & Hybrid), and I like to mess with all of them. At one time I'd take on anything. The last time was a few years back when I built my high power rigid with a custom engine & drivetrain. The clutch pushrod was a custom length and needed some strong materials used. I used a through-hard core pin and ground matching recesses on the ends where the bearing balls fit, and obviously the balls were near the diameter of inside of the mainshaft. This kept the rods suspended and centered, and they were very rigid. I didn't use the whole end for contact, just a ring at whatever diameter I preferred. I don't recall what I did with the other ends, except that I would've ground them to whatever specific shape they needed to be, or improved them.
    My wreck has slowed my action, but it's all still here waiting on me to get busy again. I was an accomplished toolmaker, so this was routine work then.
  4. The Following 2 Users Say Thank You to KickStart For This Useful Post:
    NortonDommi (Dec 26, 2017), olderdan (Dec 26, 2017)
    Thanks olderdan! We've added your Clutch Push Rod Modification to our Motorcycle category,
