Results 1 to 5 of 5
Thread: Construction workers relaying fire block length - GIF
    Altair's Avatar
    Construction workers relaying fire block length.
    Different hammering scenarios - GIF
    Efficient workers compilation - GIF
    Messing around with a coworker - GIF
    Unskilled workers - GIF
    Construction crew band - GIF
  2. The Following 8 Users Say Thank You to Altair For This Useful Post:
    EnginePaul (Jul 29, 2023), Inner (Jul 29, 2023), nova_robotics (Jul 24, 2023), Philip Davies (Jul 25, 2023), rgsparber (Jul 24, 2023), Scotty1 (Jul 23, 2023), Toolmaker51 (Jul 30, 2023), tuchie (Jul 28, 2023)
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I bet they marked off the wood before starting the camera. Notice the grin.
    Rick
    Rick
  4. The Following 3 Users Say Thank You to rgsparber For This Useful Post:
    Frank S (Jul 24, 2023), Inner (Jul 29, 2023), IntheGroove (Jul 25, 2023)
    Jan 2016
    How does that have anything to do with a fire block?
    Quote Originally Posted by Ronj View Post
    These are often installed in interior especially non insulated walls to reduce the amount of air cavity above electrical outlets should a fire start at an outlet it is more difficult for it to flame all the way to the header due to the reduced available oxygen in the cavity, increasing the burn through rating. They also add structural rigidity to load bearing walls by reducing the free column height helping to control buckling. Full sheets of plywood or OSB are used at the corners to control racking instead of the old practice of embedding a diagonal strip
  7. The Following User Says Thank You to Frank S For This Useful Post:
    Likely the 2x was marked beforehand, fire blocks in stud walls are critical in framing, the smile relates to satisfaction for temperature compensation of length, in cold weather.
    It's a funny bit. Tradesmen, one humorous lot.
