This is an outside light. So a plastic cover and pretty high up on the wall.
But thanks for the warning, will consider it when I do the next conversion.
I found one 5Watt to be sufficient to replace the original 22Watt in light intencity, but also found some of then do not last that long. So therefore this time I fitted 2, hopefully if one goes the other one will be one that lasts longer
This light stays on the whole night.
