Cutting a 127mm diameter chamfer with a 12mm radius toolpath.
This trick uses the inside of the 6" face mill inserts to cut a true large 45 degree chamfer around the perimeter of a 5" bar end. This is a big timesaver on a cnc saving a toolchange and the toolpath using a small chamfering cutter of around 400mm to one less than 40mm.
https://youtu.be/i2K0aE20Z1k?si=Ul3TjU2aCgU4znJ-
cutting a 127mm diameter chamfer with a 12mm raduis toolpath
If you are interested in reducing cycle times these videos demonstrate bi-directional milling to 1/2 cycle time & tandem milling to reduce cycle time by 60%.
Subtitles on please.
Bi-directional milling.
https://youtu.be/5q2_CBhumZg?si=fWHQz3fTuIyjAglA
Tandem milling.
https://youtu.be/84Or1BvLrvQ?si=2fPF-bSIoTjKH_cg
