https://youtu.be/FQxO_5kEMpg
Now that is a very good way of performing the task with out having a lot of bore size specific bushes.
Good job!
Well, technically, you made a broach.
A definition of a broach (Merriam Webster):
any of various pointed or tapered tools, implements, or parts: such as a cutting tool for removing material from metal or plastic to shape an outside surface or a hole
Clever implementation, cut just what you need rather than the whole hole...
Thanks winkys workshop! We've added your Keyway Cutting Method to our Machining category,
as well as to your builder page: winkys workshop's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-keyway-cutting-method-2"> <img src="/uploads/255299/homemade-keyway-cutting-method-2.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-keyway-cutting-method-2">Keyway Cutting Method</a> <span> by <a href="https://www.homemadetools.net/builder/winkys+workshop">winkys workshop</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/keyway'>keyway</a> </div> </div> </div> </div>
Congratulations winkys workshop - your Keyway Cutting Method is the Homemade Tool of the Week!
Clever idea, and well explained and documented with the included plans.
Some more nice picks from this week:
Door Frame Straightening Method by Frank S
Bifold Door by Frank S
Hub Seal Adaptor by Frank S
Deburring Tool Sharpening Method by mr_modify1
Overhead Crane Trolley by Frank S
Gland Nut Removal Method by Frank S
Clamp by orioncons36
Thickness Gauge by Make Things
Cylinder Rod Removal Fixture by Frank S
Quill Handle by GBWM
Hydraulic Cylinder Gland Nut by Frank S
winkys workshop - we've added your tool entry to our All Homemade Tool of the Week winners post. You'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
More importantly - this is your 3rd Homemade Tool of the Week win! You join these other 3-Time Homemade Tool of the Week winners: rgsparber, rossbotics, mr95gst, Paul Jones, Christophe Mineau, Captainleeward, immortalx, scorch, Brendon, Frank S, morsa, mklotz, Philip Davies, Vyacheslav.Nevolya, brianhw, kess, LMMasterMariner, jjr2001, Tuomas, olderdan, tonyfoale, bobs409, Mikhandmaker, thehomeengineer, old_toolmaker, celsoari, Bellevue Woodshop, Stevohdee, Kovanca Polock, Dimitris Polychronis, warsztatOdZera, Kwandotechnic, Mark Presling, Crusty.
You'll notice the 3-Time Homemade Tool of the Week award trophy graphic in your postbit beneath your avatar.
https://www.homemadetools.net/forum/...OfTheWeek3.pnghttps://www.homemadetools.net/forum/...eWeekIcon3.png
Here are all of your Homemade Tool of the Week winning tools:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/best-ever-guided-tap-wrench-81615#post166937"> <img src="/uploads/235652/homemade-guided-tap-wrench.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/best-ever-guided-tap-wrench-81615#post166937">Guided Tap Wrench</a> <span> by <a href="https://www.homemadetools.net/builder/winkys+workshop">winkys workshop</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/drill-press'>drill press</a>, <a href='https://www.homemadetools.net/tag/tapping'>tapping</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/horizontal-boring-machine-83209#post172658"> <img src="/uploads/241637/homemade-dowel-joint-jig.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/horizontal-boring-machine-83209#post172658">Dowel Joint Jig</a> <span> by <a href="https://www.homemadetools.net/builder/winkys+workshop">winkys workshop</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/jig'>jig</a>, <a href='https://www.homemadetools.net/tag/motor'>motor</a>, <a href='https://www.homemadetools.net/tag/dowel'>dowel</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/cutting-keyway-without-broach-91517#post205248"> <img src="/uploads/255299/homemade-keyway-cutting-method-2.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/cutting-keyway-without-broach-91517#post205248">Keyway Cutting Method</a> <span> by <a href="https://www.homemadetools.net/builder/winkys+workshop">winkys workshop</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/keyway'>keyway</a> </div> </div> </div> </div>
That was great. Thank you.
