Deadliest structural failures - infographic
I found it interesting the United States seems to have had many more than anywhere else. I would have guessed south or east Asia, given the high population density and frequent seismic and large weather events.
Quote:
Originally Posted by
schuylergrace
At least a couple of the dam failures can be attributed to poor communications between Geological and Civil engineers Failures from natural disasters are predictably unpredictable. Some bridge and structure failures possibly could be the results of alleged under the table dealings the Terrorist destructions are just that caused by a terrorist or terrorists. I imagine there will be countless scores more structure failures happen in this century largely because of an aging infrastructure hopefully thses will be demolished before they become killing zones
If commercial airplanes collisions with WTC towers caused their collapse. Then, what caused the ground floor columns to appear as if it had been flame-cut at 45 degrees inclination towards the building center? Apparently, the presumed hijackers planned to have the two towers to fall within its footprint without controlled demolition!!
mansworld
He's baaaaack.
That's not a defense or even explain the obvious. When Senator Robert Kennedy tried to find out who killed his brother President John Kennedy, they killed him too. The number of people killed following the 9/11 attacks to smother the TRUTH are staggering and exceeded the number of those killed in the attacks.
bob_3000
He's baaaaack.
mansworld
Didn't you hear? The Kennedy's are alive and well and living on Castaway Cay in the Caribbean.
Other than bomb shelters and the pyramids, name me one above-ground structure built for public use that is/was designed to withstand an attack by kinetic means...
imohtep56
There are a number of "hardened" structures in the U.S., many that folks drive by every day and don't realize what they are. For example the buildings that house primary switchgear for the communications networks, many of the Federal Reserve Bank buildings, and high security data centers are all built to withstand various sorts of possible attacks, manmade or otherwise.
