Results 1 to 9 of 9
Thread: Deburring Electric Metallic Tubing (EMT)
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    If you are running a lot of ½ inch conduit (EMT), removing all burrs can get tedious. Yet, one burr can cause the insulation to be cut and ultimately cause a fire.
    I propose using a step drill to deburr the inside of the EMT effectively. A flat file is still used on the outside.
    If you are interested, please click here.
    Thanks,
    Rick
    Rick
  2. The Following User Says Thank You to rgsparber For This Useful Post:
    Jon (May 31, 2024)
    Dec 2017
    NeiljohnUK's Tools
    I use a cone drill rather than a stepped cutter when deburring tubing, and an internal/external deburrer on the outside.
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Quote Originally Posted by NeiljohnUK View Post
    I chose a step drill because that is what I had on hand. In hindsight, I think a cone drill is more likely to leave a sharp end if the user goes in too far.
    Can you say more about the “internal/external deburrer?” Is it like the one I show on page 2?
    Thanks,
    Rick
    Rick
    Dec 2017
    NeiljohnUK's Tools
    Dec 2017
    NeiljohnUK's Tools
    I also have the original battery powered version of this tool.
    NOT Rebadged Swagelok.
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    That is a very nice tool! So, how do I make one :-))
    Rick
    Rick
  8. #7
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    I use one of these:
    https://www.kleintools.com/catalog/c...ng-screwdriver
    There is also this:
    https://www.kleintools.com/catalog/p...conduit-reamer
    which I think I will have to pick for when I have to a bunch of ends.
    What I like about these is that it gets the inside and outside at the same time, I can do multiple sizes of EMT, and I don't have to think about drill sizes.
  9. #8
    Aug 2020
    WOW brilliant !!!!
  10. #9
    Aug 2020
    Good choice.
