That is very cool. Or hot. Anyway, what are you melting, lead, or aluminum? If your melting aluminum you might look into getting heat treating oven elements, might last longer at high temps than a household oven element, not sure. I do know that heat treating elements are flexible before the first firing, but if you try to bend them after it they will break, nut sure what the difference between them and household oven elements are construction wise.
