Results 1 to 7 of 7
Thread: Die Grinder Mount
    California, central coast
    C-Bag's Tools
    Die Grinder Mount
    There have been several wonderful stationary filers on HMT. I looked at them closely but most of the work i do I don't need a flat finish and often I'm needing to take off quite a bit of material. I decided to make the die grinder from my radius cutter do double duty as a stationary die grinder.
    I had a spare 80/20 linear bearing, a chunk of 80/20. I had been wanting to cut down the drill press centering fixture I got Little Machine Shop that I'm using to mount the die grinder to the 80/20 as it was twice as long as it needed to be. So now it fits better, and I have the other half to use on the drill press again, score!
    3"x2" angle for the table and base bolted to the linear bearing. The bearing has a brake to lock the die grinder/ 80/20 unit in the bearing. I could also make the die grinder articulate up and down with a motor drive like the filers do but so far it's been uneccessary. It has come in real handy so far with small carbide bits and it has made getting into tight places much safer and easy to control. Die Grinder Mount-image.jpgDie Grinder Mount-image.jpgDie Grinder Mount-image.jpg
  2. The Following 2 Users Say Thank You to C-Bag For This Useful Post:
    Paul Jones (Sep 21, 2016), Toolmaker51 (Sep 21, 2016)
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Terrific build C-Bag, thanks for sharing this! Great re-purposing of material and really like those clamps (conduit?) for the table. Is there some kind of pinch bolt for locking the slide position? Couldn't see any from the pics.
    Thanks! ~PJ
    Mark Twain
  4. The Following 2 Users Say Thank You to PJs For This Useful Post:
    C-Bag (Sep 21, 2016), Paul Jones (Sep 21, 2016)
    C-Bag's Tools
    Thanks Wiz!
    Yup, more of the I beam conduit clamps. I have them now dedicated for different stuff I clamp to that table like a 4" vise and the sabre saw mount and when the unit is not clamped to the table they stay clamped on each unit. Handy as a shirt pocket.
    If you look in the 3rd pic on the side of the linear bearing there is a 1/4" socket head bolt. That's what 80/20 calls a brake. Clamps solid when tightened down.
  6. The Following 2 Users Say Thank You to C-Bag For This Useful Post:
    Paul Jones (Sep 21, 2016), PJs (Sep 22, 2016)
    May 2014
    Del Mar, California
    Paul Jones's Tools
    C-Bag, you have provide some really great ideas for adapting your die grinder for stationary filing. The 80/20 linear bearing is a unique adaption and very cool. Thank you for the posting and photos, Paul
  8. The Following 2 Users Say Thank You to Paul Jones For This Useful Post:
    C-Bag (Sep 22, 2016), PJs (Sep 22, 2016)
    Supporting Member jotasierra's Avatar
    Sep 2015
    país Argentina, provincia de San Juan
    jotasierra's Tools
    Hola C-bag, muy bueno ese soporte e implemento para trabajar, tambien muy interesante el soporte mutiuso..: Hattip:
  10. The Following User Says Thank You to jotasierra For This Useful Post:
  11. #6
    C-Bag's Tools
    gracias jotasierra, agradezco las amables palabras.
  12. #7
    Thanks C-Bag! We've added your Die Grinder Mount to our Grinding category,
    as well as to your builder page: C-Bag's Homemade Tools. Your receipt:
