Thread: Diesel injector testing machine - video
    Diesel injector testing machine. By BorDo TUBE. 4:53 video:
  2. The Following 2 Users Say Thank You to Jon For This Useful Post:
    mr mikey (May 21, 2024), nova_robotics (May 21, 2024)
    A useless video as far as useable information goes. but I will try and expand on it for him. As I used to have a similar rig You can basically use any bottle jack that you can drill and thread a hole in the ram to allow the fluid to pass through and secure the ram so it cannot move or just a pump with 5000PSI minimum pressure capability, and a reservoir then add a few fittings and a zero to 5000 PSI gage a line to connect the injector with but it is better if you have the injector mounted in a container with a clear sight glass for viewing the spray pattern. the spray mist is under extreme pressure and if someone had their hand near or around the nozzle the diesel will be injected into their skin
    piper184 (May 21, 2024)
    Apr 2012
    NorCal
    Saltfever's Tools
    Thanks, Frank. 1/2 the time and 10x more information in your post than the useless video.
  6. The Following User Says Thank You to Saltfever For This Useful Post:
    Frank S (May 23, 2024)
