Results 1 to 8 of 8
Thread: Differential Averaging Transmission
  1. #3
    Sep 2018
    nova_robotics's Tools
    Quote Originally Posted by BuffaloJohn View Post
    Has this been built, other than in software?
    Never been built. Probably won't be either (unless I build it). All R&D into combustion engines has dropped to zero. It's all electric vehicles now. I just thought it was a neat design because it allows crazy amounts of gear ratios with very few parts. If you add three more gears you can get up to 24 speeds, three more after that gets you to 35 speeds. Even in 24 speed configuration it's far less parts than a traditional 8 speed automatic.
    It also allows very high gear ratios. Normally you'd be limited to the transmission case size for the steepest gear ratio. If you have 20" to work with, you can only fit say a 25 tooth and a 90 tooth for a ratio of 4:1. That's all you can do because you physically can't fit larger gears with more teeth into that transmission case. With this transmission you engage forward on one half, and reverse on the other half and you can achieve very high ratios in a small transmission case size. 500:1 (or even higher) is no problem.
  2. The Following 2 Users Say Thank You to nova_robotics For This Useful Post:
    olderdan (Jul 17, 2022), Rangi (Jul 18, 2022)
