Results 1 to 9 of 9
Thread: Difficult to weld materials technique
    Sep 2018
    nova_robotics's Tools
    They're brazing in this video, but I think the methodology might also be sound for some select welding repairs as well. They drill, tap then install screws in the area to be repaired. The screw material is weldable while the base material is not. If you did this to cast iron parts, you may be able to perform a weld repair in certain circumstances.
  2. The Following 13 Users Say Thank You to nova_robotics For This Useful Post:
    Altair (Apr 6, 2022), Andyt (Apr 6, 2022), bills4-4-2 (Apr 5, 2022), clydeman (Apr 9, 2022), EnginePaul (Apr 10, 2022), Inner (Apr 7, 2022), kboy0076 (Dec 5, 2022), leo7975 (Apr 5, 2022), mr mikey (Dec 26, 2024), Rangi (Apr 7, 2022), rebuilder1954 (Apr 10, 2022), rlm98253 (Apr 9, 2022), WmRMeyers (Apr 4, 2022)
    WmRMeyers's Avatar
    Dec 2014
    WmRMeyers's Tools
    Hand shaping it on a lathe! Talk about old-school! A similar cutter could be used in milling machine, driving by a fly-cutter sort of tool holder, if you happen to have such a machine. Or just filed.
  4. The Following 2 Users Say Thank You to WmRMeyers For This Useful Post:
    mwmkravchenko (Apr 9, 2022), nova_robotics (Apr 4, 2022)
    Elizabeth Greene's Tools
    I'm impressed;That's beautiful. 10/10 for hand indexing a gear while cutting the teeth by broaching using a ground form tool on the lathe. That's awesome!
    Mar 2020
    Too many close spaced holes will weaken the structure. A better approach is to drill less holes, say 3 or 4 screws spaced apart, and stay away from the edge/face of the gear.
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Cast Iron is usually easy to gas weld with a good rod. Bronze welding also works well and is ideal for many gears, amazingly strong and tough stuff. The guy did a nice job but the screws probably aren't needed for anything more than a framework.
    Bronze could be Tobin for small gears but for large ones under stress Manganese Bronze or Nickle Bronze would be better.
    Just thought I'd throw in stitching for crack repair. it is common, can often be done in situ and once peened indistinguishable from the surrounding area.
    https://www.metalockengineering.com/...tal-stitching/
  8. The Following 2 Users Say Thank You to NortonDommi For This Useful Post:
    nova_robotics (Apr 6, 2022), rlm98253 (Apr 9, 2022)
    Isambard's Avatar
    Aug 2019
    Hawke's Bay, New Zealand
    Reminds of a job my father did back in the Depression. He was working in a quarry up a river where there was a only steam power.
    Several teeth stripped on the rock crusher. My father hand drilled holes on a 8" face for 1 inch bolts! He then filed the profiles...
    A replacement gear was months away, apparently.
  10. The Following 2 Users Say Thank You to Isambard For This Useful Post:
    mwmkravchenko (Apr 9, 2022), rlm98253 (Apr 9, 2022)
  11. #7
    Aug 2012
    Australia
    desbromilow's Tools
    a bit cringey at 7:46 when you observe the electrical "box" on the work bench in the background - single cores jammed into the GPO
    noticed a lot of slop in the machine - tool post appeared to tilt/ lift a few times, and the spindle lock wasn't - just goes to show how a craftsman can compensate for the limitations of their machine.
  12. #8
    Supporting Member Skun Knuckles's Avatar
    Dec 2017
    Gippsland Victoria Australia
    Skun Knuckles's Tools
    I was told many years ago “Do what you have to do to get the job done!”
    When I was young and poor I learnt a trade, and after many years of hard work I’m not young anymore.
  13. The Following 2 Users Say Thank You to Skun Knuckles For This Useful Post:
    bigtrev8xl (Apr 10, 2022), Frank S (Apr 9, 2022)
  14. #9
    Apr 2017
    I did this to my large lathe about40 years or more ago. I didn't remove the gear as it was on a large group. I just drilled the holes, taped them, put the studs in, welded them and then free hand ground the teeth to shape. It was a 16X48 inch and has worked fine
    every since
  15. The Following 2 Users Say Thank You to clydeman For This Useful Post:
    bigtrev8xl (Apr 10, 2022), nova_robotics (Apr 9, 2022)
