Does anyone have an explanation as to what would cause this.
Today I drug out a pair of digital calipers put a new battery in them since it seams every time i want to use anything battery operated the battery is flat or if I happened to forget to remove the battery it will be corroded and the tool will be ruined. So it should be of no surprise that i have little faith in battery operated stuff.
But having a caliper read exactly half is a new one on me, also it is repeatable no matter how many times it is switched off and on zero checked then measure anything. The reading is always exactly half and it doesn't matter if imp. or mm.
