Results 1 to 10 of 11
Thread: DIY Diamond Abrasive Coatings
  1. #9
    Jan 2017
    Diamond tooling
    Quote Originally Posted by mikeyrocks View Post
    Well a newbie to this forum but I have a fair amount of knowledge in this area which I have been working with for almost 20 years now as a lapidary (stone cutter). There are several methods to use diamond powder (bort). Sintering is diamond mixed within the metal. Plated onto the surface of the metal in a plating process which traps the diamond particles for a while. Resin bonding is glueing, either in a thin coating or a very thick coating. Diamond paste or simple loose diamond bort. Next and very important.....there are various diamond borts available. Basically there is plain bort, then there is bort that is prepped for resin bonding or gluing, bort that is prepped for sintering, and so on. So get the correct bort for the application you wish to work with and you should get better results.>>>>>Now for this discussion here:-there is a diamond welding rod available which is brass tubing filled with diamond bort for torch welding. You can buy it or make your own. Generally looks a bit crude after it is done though.>>>>>Here is a method that you might find appealing though for making shaped diamond tools for grinding. Make an arbor from steel, attach a piece of old growth Redwood to it then cut/grind it down to the shape you want to grind with. Apply diamond paste and go to work, recharge as needed. When charging or recharging rotate the tool slowly so you can work the diamond into the wood rather than fling it off, Initially I presumed that a hard wood would be appropriate and some do use maple but an old experienced hand at this, Daniel Lopatki (of Lopatki Lapidary Supplies) out of New Mexico set me straight . The softer Redwood absorbs the diamond particles better and surrounds them more easily....making a better tool.>>>>>>Now for those wanting to glue diamond...get the properly prepped bort then try to find some phenolic resin of the correct hardness. Eastwind Diamond Abrasives makes the best diamond discs, belts, wheels and pads, etc. that there are, in my experienced opinion. And makes them here in the USA in Vermont. He settled on phenolic resin because it's strong enough to hold the particles in place. He found the right combo, hard enough to not wear out too quickly but soft enough to wear down and expose fresh cutting diamond particles. So keep that in mind as you try various epoxies, filled epoxies, etc. for your own experiments. Steel filled might be too hard to do a good job. I don't have a recommendation for you yet and I am still experimenting in this field. I've even tried zinc rich spray paint early on. I don't know if any here knows about the phenolic resin family but I am all ears. Mohan lapidary supply in China is making belts and discs using a more rubbery resin than Eastwind I have just started trying them a few months back...my initial reaction is they are too soft or gummy. I am withholding my final opinion on these yet...not enough usage yet. Oh I use diamond bort from 36 grit particles down to 50,000 grit.
    There is a company in West Jordan, Utah named Anthon Engineering that does custom diamond tooling, wear parts, and other stuff. They manufacture a brazing rod in a few different grits of diamond so you can make your own tooling. This is commonly used in the lapidary field to turn plumbing fittings called "bell reducers" or reducing couplings into cup wheels for sphere grinders. It can be used on steel "cores", and even removed, as the brazing alloy has a lower melting point than steel. you can take any steel tubing that has a higher melting point than this brazing rod and coat one end, and make a core drill out of it. I've seen HUGE homemade DRAG SAWS that used this, or used diamond segments from HANS Lapidary, in China, to saw 4 or 5 foot diameter rocks in half! If there's a need, and where there's a will, there's a way!
    P.S. Thanks a bunch for sharing your expertise and your experience with me!
