hard still cuts or grinds and sands...just tales longer....and the right tools to do so. I wouldn't try to cut, just polish down a bit, unless you can get zero run out and then still booger to get it right.Ive used diamond stones or cbn to knock some down a bit. some of the china stuff is just rough and needs a bit of polishing to knock off the high spots.make sure you only press on the inner race when presing onto the shaft. and outer race pressing into housings...china bearings are soft...as are some other's. Ive seen effed up new bearings and never knew that they did it.. bearings run quiet, if not something is rong....be sure to make a good cover so no debris of any kind get to the bearings. seals work great,,, but...some stuff still gets by seals bearings seals. especialy prickley slivers.
you can always put a shaft in a drill and spin it agnist the belt sander if your belt sander isant portable....lots of ways to skin cats and not get bitten.
Ok thanks for all the info.
