Here is more detailed explanation of the making process:
https://www.instructables.com/id/Diy...Puller-Pusher/
Tuomas (Sep 27, 2020)
Screw operated pullers has also annoying habit, that when something is really tight. It happens that the axle starts to turn along with the puller.
When removing gear from the electric motor for example. You need to find the way to lock the axle, to be able to tighten the puller.
Toolmaker51 (Sep 28, 2020)
Thanks Tuomas! We've added your Hydraulic Puller/Pusher Claw Support to our Miscellaneous category,
Thanks Tuomas! We've added your Hydraulic Bearing Puller/Pusher Support to our Miscellaneous category,
