Here is more detailed explanation of the making process:
https://www.instructables.com/id/Diy...Puller-Pusher/
I'll just say it's terrific. Can you imagine removing a large engine dampener, by working a handle instead of messing with a combination or socket wrench?
Screw operated pullers has also annoying habit, that when something is really tight. It happens that the axle starts to turn along with the puller.
When removing gear from the electric motor for example. You need to find the way to lock the axle, to be able to tighten the puller.
Thanks Tuomas! We've added your Hydraulic Puller/Pusher Claw Support to our Miscellaneous category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-hydraulic-puller-pusher-claw-support"> <img src="/uploads/235817/homemade-hydraulic-puller-pusher-claw-support.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-hydraulic-puller-pusher-claw-support">Hydraulic Puller/Pusher Claw Support</a> <span> by <a href="https://www.homemadetools.net/builder/Tuomas">Tuomas</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/puller'>puller</a>, <a href='https://www.homemadetools.net/tag/bearing'>bearing</a> </div> </div> </div> </div>
Thanks Tuomas! We've added your Hydraulic Bearing Puller/Pusher Support to our Miscellaneous category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-hydraulic-bearing-puller-pusher-support"> <img src="/uploads/235822/homemade-hydraulic-bearing-puller-pusher-support.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-hydraulic-bearing-puller-pusher-support">Hydraulic Bearing Puller/Pusher Support</a> <span> by <a href="https://www.homemadetools.net/builder/Tuomas">Tuomas</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/puller'>puller</a>, <a href='https://www.homemadetools.net/tag/bearing'>bearing</a> </div> </div> </div> </div>
looks good. Can one buy puller bodies to be used with porta power pumps?
