Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Diy hydraulic puller / pusher
    Jyväskylä Finland
    Tuomas's Tools
    Here is more detailed explanation of the making process:
    https://www.instructables.com/id/Diy...Puller-Pusher/
  2. #12
    I'll just say it's terrific. Can you imagine removing a large engine dampener, by working a handle instead of messing with a combination or socket wrench?
  3. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    Tuomas (Sep 27, 2020)
  4. #13
    Jyväskylä Finland
    Tuomas's Tools
    Screw operated pullers has also annoying habit, that when something is really tight. It happens that the axle starts to turn along with the puller.
    When removing gear from the electric motor for example. You need to find the way to lock the axle, to be able to tighten the puller.
  5. The Following User Says Thank You to Tuomas For This Useful Post:
    Toolmaker51 (Sep 28, 2020)
  6. #14
    Thanks Tuomas! We've added your Hydraulic Puller/Pusher Claw Support to our Miscellaneous category,
  7. #15
    Thanks Tuomas! We've added your Hydraulic Bearing Puller/Pusher Support to our Miscellaneous category,
  8. #16
    Feb 2018
    looks good. Can one buy puller bodies to be used with porta power pumps?
