Thread: DIY MOT STICK WELDER DANGER DO NOT TRY THIS
    Mar 2015
    For some time I wanted to build a MOT stick welder. Well I got a transformer from an old microwave oven and tore the secondary wingdings out. Rewound the secondary with # 12 AWG left the primary winding intact. So I needed another transformer I found on in an old 12 volt battery charger this thing is huge.I tore the secondary winding off and damaged the primary winding. so I replaced the primary winding 180 turns and the secondary winding and they must wind in the same direction. Here is where I messed up since this transformer was much bigger I used # 10 AWG for the secondary note the other transformer done with #12 AWG wire. Well the secondary's must be wired in series while the primary needs 120 volt from two different sources.
    I got it hooked up got one rod burnt looked over and smoked the little transformers secondary winding. Rewound 18 turns with #10 AWG and I am welding away just fine.DIY MOT STICK WELDER DANGER DO NOT TRY THIS-transformer.jpg
  2. The Following User Says Thank You to ken4uall For This Useful Post:
    kbalch (Mar 6, 2015)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Glad you got it working without too much damage.
    Let's see a photo of the finished unit; we'll get it added to the site straightaway!
    Ken
    Thanks for the post, ken4uall. Members here who are looking to build a welder will be forewarned.
