DIY Powered Disc Sander
https://youtu.be/ZukfqM8UDsM
DO NOT THROW THE OLD WASHING MACHINE MOTOR IN THE TRASH / DIY Powered Disc Sander.I will show you an easy way to create a disc sander, I will use wood and two-component poxypol glue with which I will glue the sandpaper. I will show you how easy it is to remove the old sandpaper from the wooden disk. These are steps that I think will be useful to you in making a disk sander. Thank you for your attention. In the video you will see a box that is adapted for the electric motor. I will leave links for videos in which I show how you can wiring an electric motor.
https://youtu.be/zPHsf2CalFU
https://youtu.be/7kjyc0X_ubI
https://youtu.be/_PYPW_Bz8Sg
https://youtu.be/WkTehIM9NU4
https://youtu.be/vHkbSsg2eN4
https://youtu.be/XPgZ0ycpINg
https://youtu.be/CjBZeLdqJP0
======== This is links for How to wiring washing machine motor =======
Subscribe My Channel - http://tiny.cc/c3zq9y
Thanks HandmadeCreativeChannel! We've added your Disc Sander to our Disc Sanders category,
as well as to your builder page: HandmadeCreativeChannel's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/homemade-disc-sander-84">
<img src="/uploads/239499/homemade-disc-sander-84.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/homemade-disc-sander-84">Disc Sander</a>
<span> by <a href="https://www.homemadetools.net/builder/HandmadeCreativeChannel">HandmadeCreativeChannel</a></span>
</div>
<div class="tags">tags:
<a href='https://www.homemadetools.net/tag/disc-sander'>disc sander</a>, <a href='https://www.homemadetools.net/tag/motor'>motor</a> </div>
</div>
</div>
</div>
This is the complete program I was hoping for. I don't know a lot about electronics and electrical work. (I was struck by lightning as a teenager, so I always avoided it until more recently. And I still don't love it.)
Outstanding series!
Great idea! I have made a similar sander but rather than glue I have used a 178mm Backing Pad Hook & Loop Converter ( https://tinyurl.com/y62lwe2b ) and I use pads with Hook & Loop backing (https://tinyurl.com/y62lwe2b)
