Results 1 to 6 of 6
Thread: DIY Temperature Controlled Window Fan
    Jun 2019
    m2rechtin's Tools
    Hello,
    I built a fan that will only blow air into a room when the temperature outside is lower than the temperature inside. Check it out and let me know what you think!
    -Michael
  2. The Following 3 Users Say Thank You to m2rechtin For This Useful Post:
    Altair (Aug 11, 2019), JKeetonKnives (Aug 11, 2019), Jon (Aug 15, 2019)
    Thanks m2rechtin! We've added your Temperature-Controlled Fan to our Heating and Cooling category,
    as well as to your builder page: m2rechtin's Homemade Tools. Your receipt:
    Knife Maker
    JKeetonKnives's Avatar
    Aug 2019
    Texas
    JKeetonKnives's Tools
    Dude that's pretty awesome! Cool idea!
    J. Keeton
    "RedBeardOps" on both Youtube and Instagram
    Youtube: https://www.youtube.com/redbeardops
    Instagram: https://www.instagram.com/redbeardops/
    jdurand's Tools
    If you ever need to do something like that tiny and cheap, you can use two silicon diodes (1N4148) as sensors along with an 8-pin comparator chip and two resistors. You probably need a transistor to help the comparator drive a DC fan directly or a relay for an AC fan. Won't give any readout but will switch fan on/off based on which sensor is hotter.
  6. The Following User Says Thank You to jdurand For This Useful Post:
    m2rechtin (Aug 12, 2019)
    Jun 2019
    m2rechtin's Tools
    Thanks for the tips jdurand! I will have to try that out.
    jdurand's Tools
    Quote Originally Posted by m2rechtin View Post
    Let me know if you need any circuit help with that, you can also add hystorisis so there's some room between the turn on and turn off points.
