Results 1 to 5 of 5
Thread: DIY Welding Helmet Integrated Neck Protector
    Supporting Member tsbrownie's Avatar
    Feb 2019
    tsbrownie's Tools
    DIY Welding helmet integrated neck protector. Keeps sun and reflected light off my neck and reflections out of my helmet. Also keeps sparks and blueberries off neck and throat.
    I made it to be cooler and easier to remove than caps, or doorags, etc. because I often work in full sunlight in summer and want max draft and don't want to wear it unless I'm running an arc. It's also easy to remove, clean, replace, repair...
    MATERIALS:
    - Flame proof or flame retardant cloth (the blue jean material shown is NOT flame proof or retardant)
    - Cotton thread, thick like darning thread (NOT synthetics like polyester)
    - White glue (to coat threads when done)
    - Drill bit, very small, just bigger than thread
    - Optional: marker to color threads as desired
    WARNINGS:
    - Welding can be dangerous, if you do not know, don't do it. Get training.
    - This neck drape is NOT industrial quality, it only protects against only occasional small blueberries, sparks and things like sunburn or reflection burns.
    - No assurances are implied on its ability to work in your application.
    - Always use proper safety procedures and safety equipment. If you don't know, learn first or don't do it.
  2. The Following 4 Users Say Thank You to tsbrownie For This Useful Post:
    greyhoundollie (Mar 16, 2020), Jon (Mar 19, 2020), n9dug (Mar 16, 2020), thevillageinn (Mar 23, 2020)
