DIY WIRE TWISTING TOOL AND FRAMING SQUARE STAND!!!
https://www.youtube.com/watch?v=sY1utrjTEmM&t=336s
Thanks orioncons36! We've added your Wire Twisting Tool to our Metalworking category,
as well as to your builder page: orioncons36's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-wire-twisting-tool-3"> <img src="/uploads/253230/homemade-wire-twisting-tool-3.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-wire-twisting-tool-3">Wire Twisting Tool</a> <span> by <a href="https://www.homemadetools.net/builder/orioncons36">orioncons36</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/drill-bit'>drill bit</a> </div> </div> </div> </div>
Thanks orioncons36! We've added your Framing Square Stand to our Measuring and Marking category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-framing-square-stand"> <img src="/uploads/253235/homemade-framing-square-stand.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-framing-square-stand">Framing Square Stand</a> <span> by <a href="https://www.homemadetools.net/builder/orioncons36">orioncons36</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/square'>square</a>, <a href='https://www.homemadetools.net/tag/stand'>stand</a> </div> </div> </div> </div>
That's a tool I could have used several times in the past. Thanks much!
I like how you spend a lot of time making these tools look like they aren't made out of scraps. It reinforces the notion that you can make a lot with a little.
Neil
Its good; easier cost wise to a tie-wire twister. But you'll get a proper bind with the wire encircling the bundle [cinched] one full turn beforehand.
Not yet convinced on the square holder but it sure cultivates ideas.
Glad you found it useful. Thank you.
Thank you.
