Results 1 to 5 of 5
Thread: Double-ended pin vise accessory
    In my ship modeling youth I saved my pennies and bought Starrett's four collet, double ended pin vise...
    I later learned that, when using it with tiny drills or taps, keeping it vertical with some mechanism could prevent a lot of broken tools. Also, it lacked the swiveling top found on typical jewelers' screwdrivers, another useful feature.
    So, I took a tiny scrap of brass and solved both problems. Two different diameters turned on one end allow it to be mounted in whichever collet is not being used to hold the drill or tap...
    while a chamfered hole in the other end accepts pointed guide rods held in the (non-running) Unimat or drill press. When the guide rod is not needed, the chamfered hole serves as a nice, smooth substitute for a swiveling top.
  2. The Following 10 Users Say Thank You to mklotz For This Useful Post:
    bruce.desertrat (Feb 13, 2024), butlerandrew (Feb 13, 2024), Eaglewood (Feb 19, 2024), Jon (Feb 14, 2024), rebuilder1954 (Feb 13, 2024), techcollect (Feb 19, 2024), that_other_guy (Feb 24, 2024), thevillageinn (Feb 13, 2024), Toolmaker51 (Feb 18, 2024), winmac (Feb 13, 2024)
    Thanks mklotz! We've added your Double-Ended Pin Vise Accessory to our Tapping and Threading category,
    May 2021
    Great idea!
    Will probably make something similar for my own use.
    Quote Originally Posted by butlerandrew View Post
    Great idea!
    Thanks for the kind words.
    If you make your own...
    Check any other double-ended pin vises you may have (I have two). You may want to adjust the diameters of the turned down sections (or add another) so the device can be used on the other vises. I did this to avoid having to make two of these accessories.
    If you decide to fit a jeweler's screwdriver swiveling head, consider making the chamfered hole in its axle so that you have both functions (swivel and alignment) all in one place.
  6. The Following User Says Thank You to mklotz For This Useful Post:
    butlerandrew (Feb 19, 2024)
    May 2016
    Don42's Tools
    Nice! I'll bet it would serve nicely as a pin vice with "spinner" top, for drilling or tapping small objects held in the clever PVC vise posted by another maker.
    Download plans for vises.
  8. The Following User Says Thank You to Don42 For This Useful Post:
