Results 1 to 10 of 18
Thread: Dremel fan
    Dremel fan
    Dremel now makes a tiny fan to blow dust away from the tool you are using...
    http://www.amazon.com/Dremel-490-Dus...el+accessories
    It comes permanently attached to one of their collet chucks which is fine if you use collets to hold tools. I prefer to use their 3jaw chucks since many of my tools have different size shafts and switching collets becomes tedious if using several different tools. So, I took a bit of nylon-like plastic from the "what is this stuff?" bin and machined something that looked like an eight-bladed fan with blockish blades. Using miniature carving chisels and, of course, a Dremel, I manufactured something that friction fits the base of the 3jaw chuck.
    This photo shows the Dremel fan and 3jaw chuck along with the fan I made...
    and this one shows the fan in place on my Milwaukee-Dremel...
    Despite lacking the ducting of the Dremel fan, my bit of sculpture produces more airflow than the Dremel fan.
    A bit about the Milwaukee-Dremel...
    I was casting about for a more powerful rotary tool than the Dremels I have. Dremel's newer model, the 8220, looked attractive but, while scouring Amazon, I happened upon Milwaukee's latest offering.
    It has exactly the same spindle thread as the Dremels and the nose thread (3/4-12) is the same so screw-on things like the router also fit. Best of all, it takes the Milwaukee M-12 batteries. This is the same battery as used in my drill so I already have two and the charger. Milwaukee sells the unit without the battery (what I bought) although it's available with battery if you don't have one. I've been very happy with the Milwaukee batteries so I was pleased to be able to use them with this tool.
    The Milwaukee has more power and less spindle run-out than the Dremel 8220. It's one drawback is that it is noisy at the higher speeds.
  2. The Following 13 Users Say Thank You to mklotz For This Useful Post:
    bob_3000 (Jul 17, 2023), C-Bag (Jan 28, 2016), Captn Roy (Jun 12, 2018), Christophe Mineau (Jan 28, 2016), Home-PC (Jul 24, 2020), Jon (Jan 26, 2016), kbalch (Jan 26, 2016), oldcaptainrusty (Nov 24, 2017), Paul Jones (Jan 26, 2016), PJs (Jan 27, 2016), rlm98253 (Nov 20, 2017), tom petersoin (Mar 11, 2016), toma (Feb 8, 2018)
