Results 1 to 4 of 4
Thread: Drill Bit Sharpening Jig
    Supporting Member The Hobby Machinist NZ's Avatar
    Jan 2023
    New Zealand
    The Hobby Machinist NZ's Tools
    In this video I skim over the build of a drill bit sharpening jig that I started building over a year ago. I also introduce a commercial sharpening jig which works really well.
  2. The Following 4 Users Say Thank You to The Hobby Machinist NZ For This Useful Post:
    emu roo (Sep 30, 2025), Jon (Oct 14, 2025), Moby Duck (Oct 1, 2025), terence b (Sep 30, 2025)
    Thanks The Hobby Machinist NZ! We've added your Drill Bit Sharpening Jig to our Sharpening category,
    as well as to your builder page: The Hobby Machinist NZ's Homemade Tools. Your receipt:
    ironwrx's Tools
    I love the jig that you built. The problem is that when you start your grind the bit is closer to the wheel, but when you swing the bit upwards, it gets further away from the wheel. This is exacerbated by the fact that being a wheel, the higher an object you’re grinding is, the further away the grinding surface of the wheel it becomes. This problem could be fixed by setting your jig against a belt sander instead of a curved wheel. Great idea. Good build!!
    Mar 2018
    Hoosiersmoker's Tools
    I bought a cheap Drill Doctor and was amazed at how accurate the grind was. It even did a decent job at split pointing the bits. Working mostly in wood, hand sharpening is usually "good enough". I have a separate set of bits for metal and use the Drill Doctor if I need to sharpen them.
    "The man who views the world at 50 the same as he did at 20 has wasted 30 years of his life."
    - Muhammad Ali
