Results 1 to 6 of 6
Thread: Drill-powered metal cutter - GIF
Hybrid View
    May 2024
    Drill-powered metal cutter.
    CNC foam cutter - GIF
    Improvised PVC pipe hole cutter - GIF
    Magnetic drywall cutter - GIF
    Rotary cutter - video
    emu roo (Aug 16, 2025)
    $10 on Amazon if you want to try one...
    https://www.amazon.com/Jikbeed-Metal...s%2C285&sr=8-1
  4. The Following 3 Users Say Thank You to mklotz For This Useful Post:
    albertq (Aug 16, 2025), emu roo (Aug 16, 2025), PJs (Aug 16, 2025)
    Oct 2012
    Lafayette, Indiana
    sossol's Tools
    I got one for free from Amazon Vine. I did not give it a great review. It only worked on thin stiff steel. Anything thinner or softer would fold up between the wheels and jam the tool because the floating wheel was out of true. My review is the one with the parts spread out on a green background.
    I replaced the bearing under the floating wheel because it was sloppy, made a new bearing pin because the original was not straight, and sharpened the cutting edge. It works reliably now.
    Neil
  6. The Following 3 Users Say Thank You to sossol For This Useful Post:
    emu roo (Aug 16, 2025), Floradawg (Aug 16, 2025), PJs (Aug 16, 2025)
    Jul 2018
    Flora, MS
    Floradawg's Tools
    Quote Originally Posted by sossol View Post
    Neil
    Great idea not very well carried out.
  8. The Following User Says Thank You to Floradawg For This Useful Post:
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    I looked at the reviews and most complained about poor quality of the device and of the cut. Most of these seem to cut fine on flat straights, but deviate from that and all best are off.
    I've tried nibblers and electric shears and have had mixed results - poor results on corrugated roofing metal. Have cut over 50 pieces of corrugated roofing with a 7 1/4 circular saw with a metal cutting blade. Just make sure you have the right kind - the thinner the metal, the more teeth are needed.
    My go to on metal cutting blades has been the Diablo (brand of Freud) Steel Demon blades. I have used them in my metal cutting saw and they also work great for cutting roofing metal.
    https://www.amazon.com/Diablo-D0770F.../dp/B01JED79DY
  10. The Following 2 Users Say Thank You to BuffaloJohn For This Useful Post:
  11. #6
    Oct 2012
    Lafayette, Indiana
    sossol's Tools
    Quote Originally Posted by BuffaloJohn View Post
    I usually use hand shears for thin material, and have an Eastwood open-throat manual shear which works very well, but it's too cumbersome to be carting around to where I need to use it, which is why I was interested in this mini one. Now that I've sorted it out it works really well, so I will get some use out of it, but the average user can't be expected to have a lathe and tool steel on-hand to make repair parts. I still mostly use my ancient Wiss shears.
    Neil
