Results 1 to 7 of 7
Thread: Drill-press improvement: when every centimeter counts
    Supporting Member yair feldmann's Avatar
    Feb 2021
    Raanana, ISRAEL
    yair feldmann's Tools
    Using a table drill-press can be annoying when dealing with fairly long pieces, longer than the limited space found between the bit and the drill-press table.
    I could not find a longer tube with the exact diameter of the one which came with the machine (unless you buy in China some tons, produced especially for you…)
    So, this is what I did: from a drying rack for laundry – or was it a bathroom-sink support? – I salvaged two T-shaped metal frames, and hung them to the wall, above the drill-press. Then I detached the "head" containing the motor and the pulleys and fixed it to the frames, thus gaining valuable 28 cm! A threaded rod connects the base to the top and prevents distortion while drilling and pressing down the bit.
ID:	39087Click image for larger version.
Name:	המקדחה על המבנה.jpg
ID:	39088Click image for larger version.
    I then re-installed the table-lift previously made, shown here
  2. The Following 4 Users Say Thank You to yair feldmann For This Useful Post:
    Jon (Apr 3, 2021), mklotz (Apr 3, 2021), nova_robotics (Apr 12, 2021), Scotsman Hosie (Apr 6, 2021)
