Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Drilling machine
    Vyacheslav,
    I love how you make nice things from near nothing. I did the same in my youth.
    I would echo the same comment that Al made about a brace on the main column. It would be easy to have a bolt on one which went back to the wall, then you could still remove the head if necessary.
  2. The Following 2 Users Say Thank You to tonyfoale For This Useful Post:
    olderdan (Feb 13, 2017), Paul Jones (Jan 27, 2018)
  3. #12
    Elegant. 3 tools needed to fabricate. Angle grinder, welder and piece of carbide to shape angle grinder disk for gear teeth. Two questions-- 1. How to hold spindle ball bearings inside square tube? 2. What is size or part number of ball bearings?
  4. #13
    Dec 2016
    You sir, are a true innovator.
  5. #14
    Perth Ontario Canada
    Quote Originally Posted by Ed Weldon View Post
    Could be a quick tack weld on the corner. Would not do much damage if any to the bearing and hold it in place.
  6. #15
    I would not recommend any attempt to weld on or near a functional part of an expensive ball bearing. There are other ways to accomplish the locating and confining rotation of an outer ball bearing race that do not risk physical distortion of its geometry. In a shop with scarce resources 4 small carefully carved wood wedges (with locking tapers in the inside corner openings of the square tube) anchored with some tree sap would work. Personally I'd prefer making those more or less triangular spacers from steel with a close slip fit and retaining them with a minimum of epoxy adhesive. When bearing replacement is required application of heat at about 200C will cause the epoxy to break down and be easily cleaned off the spacers and the inside of the tube.
  7. #16
    Add my vote to that.
  8. #17
    While I have numerous times tack welded bearing races to or in parts this is only done on when things I term single use throw away get it done and move on. I would never consider tack welding to a bearing race that was needed to last for any period of time. Its not good to even allow stray current to pass through a bearing
    Download plans for drilling and drill preses.
