Well it doesn't apply to the sparkies or tin bashers. It definitely applies to the iron workers, welders and millwrights though.
Sorry don't remember mentioning trades in this video.
One of Propane's by products as it burns is water vapour. You are actually condensing the water onto the cool steel.
I hear you on the misapplication of torque wrenches as well. I have had those conversations. Go to where? Now there is a little loss in the sockets between the extension and the socket end. But not that much. A few percent at the most. Actually thinking this through that may be erroneous as well. If the rotation is blocked where in the ratchet - extension - and then socket is the torque disappearing to? Potential twist in the extension shaft. That is about it as far as I can think through.
I actually worked this out one day and it's pretty interesting.
If you're using an impact then the "springiness" of the extension will limit the torque at the bolt. The extension is essentially a torsion rod and the impact is energy (or impulse?) limited. So some of that energy will go into doing work on the torsion rod instead of being transferred to the bolt. Somebody has already noticed this and turned it into a product. You can buy torque limiting extensions off the shelf.
BUT! If you look at what happens at the extension when you have a conventional torque wrench on there, the extension is sloppy at both end connections. It will bend over a few degrees in the direction of the force applied. That actually increases the effective lever arm distance between the point load (your hand) and the bolt. So if your torque wrench is set to exactly 100 lbs-ft, the fastener will experience a slightly greater torque, say 102 lbs-ft. The effect is small, only a few percent. But still. Opposite to what everyone assumes will happen.
I've long wondered how those work. I understand the torsion rod principle (anyone who has fought a stubborn bolt would), but not how that ultimately limits rotation. Obviously the smaller diameter takes less torque to twist up, but that's where my understanding ends. It seems to me that the rod would store the energy until it reaches its limit, then stop twisting and transfer it on to the socket.
Neil
I like to spray paint on fresh welds while they are hot, the first coat may blacken but another quick coat a few minutes later covers that.
socket extensions eat a lot of torque on an impact gun, should not affect a manual torque wrench.
Thanks mr_modify1! We've added your Rapid Paint Drying Method to our Painting category,
as well as to your builder page: mr_modify1's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-rapid-paint-drying-method"> <img src="/uploads/252601/homemade-rapid-paint-drying-method.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-rapid-paint-drying-method">Rapid Paint Drying Method</a> <span> by <a href="https://www.homemadetools.net/builder/mr_modify1">mr_modify1</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/painting'>painting</a> </div> </div> </div> </div>
