It’s a challenge to get to the air drain on my air compressor so I made it easier. An auto drain would be nice but they’re a little spendy:)
https://youtu.be/M2uPk2lOy20
Thanks Sgbarker! We've added your Air Compressor Drain Valve Extension to our Air Compressors category,
as well as to your builder page: Sgbarker's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-air-compressor-drain-valve-extension"> <img src="/uploads/227993/homemade-air-compressor-drain-valve-extension.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-air-compressor-drain-valve-extension">Air Compressor Drain Valve Extension</a> <span> by <a href="https://www.homemadetools.net/builder/Sgbarker">Sgbarker</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/air-compressor'>air compressor</a>, <a href='https://www.homemadetools.net/tag/valve'>valve</a>, <a href='https://www.homemadetools.net/tag/drain'>drain</a> </div> </div> </div> </div>
thats a great Idea
One of the main causes for compressor tanks going bad is the drains are so inaccessible most folks don't drain theirs regularly
well done sir!
I have never understood why the manufactures do not apply a coating on the interior of pressure tanks to prevent rusting.
You are right Frank
I did the same thing years ago, using 3/8" copper tubing and a 1/4" ball valve. The ball valve is much handier to operate than the original type.
