Results 1 to 7 of 7
Thread: Easy way to motorize a lead or feed screw.
Hybrid View
    olderdan's Tools
    My old SB lathe has a feed apron but uses a keyway on the leadscrew to drive it, this means changing the gear train from threading to feed speeds which is a real pain for making multiple parts (the lathe does not have a QC gearbox). A separate drive from the tailstock end seemed the most practical as the gear train for screw cutting could then be left set up. The only alteration to the lathe is to drill and tap the end of the leadscrew for a hub for the Poly V pulley. I used a 12 volt DC Bentley golf trolley motor which has an integral gearbox and a PWM controller, power source is an old battery charger giving 6 or 12v (the newer intelligent chargers are no good for this). The drive is mounted on a friction pivot to disengage so after turning a part I just have to pull the motor forward, engage the tumbler and screw-cut etc a matter of a few seconds. It has also been a boon to adjust the feed rates on the fly Hardinge style for optimum removal and finishes, it will slow down enough for me to use the graduations on the hand wheel. Of the many mods I have done to this lathe this has been the most useful and has given a more modern feel to using it. As there is no interlock between the two drives the belt drive will pull the motor forward and slip if the sequence is forgotten and acts like a mechanical fuse.
    Easy way to motorize a lead or feed screw.-p1010057.jpgEasy way to motorize a lead or feed screw.-p1010059.jpgEasy way to motorize a lead or feed screw.-p1010061.jpgEasy way to motorize a lead or feed screw.-p1010063.jpg
  2. The Following 13 Users Say Thank You to olderdan For This Useful Post:
    allenz (Apr 21, 2020), benkeller3 (Apr 27, 2020), bobs409 (Apr 21, 2020), davesrepair (May 31, 2025), DIYer (Apr 19, 2020), emu roo (Aug 8, 2025), jflueger (Apr 19, 2020), Jon (Apr 23, 2020), Paul Jones (Apr 20, 2020), philippacificnw (Jun 8, 2025), sossol (Apr 20, 2020), tonyfoale (Apr 21, 2020), Tuomas (Apr 30, 2020)
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Very useful description and photos.
  4. The Following User Says Thank You to Paul Jones For This Useful Post:
    Alan,
    good one as usual.
    what is the ratio of that gearbox and are they readily available?
  6. The Following 2 Users Say Thank You to tonyfoale For This Useful Post:
    emu roo (Aug 8, 2025), olderdan (Apr 21, 2020)
    Stockholm, Sweden...
    DIYSwede's Tools
    Alan,
    good one as usual.
    Ball park figure (but unfortunately not about its GB ratio, Tony):
    Facts stated elsewhere about the golf trolley unit: 12V, 200W in, max 5mph (and a wheel dia of 26,5 cm) would give 160-ish rpm out at full throttle.
    No figure given for its duty factor, but there's a remote control unit that can be used up to 100 m (in open terrain)...
    Cheers
    Johan
    PS: Readily available, but certainly with a hefty price tag given its origin, Tony.
    A car/ lorry wiper motor from a scrap yard would get you the same performance with a 100% DF at a discount,
    and they're also originally designed for minimum noise. D
  8. The Following 2 Users Say Thank You to DIYSwede For This Useful Post:
    olderdan's Tools
    Thanks Tony, I have been unable to find the original supplier of the motor as so many sites have shut down recently. The motor has no info at all (Chinese) but I measure the output speed of the gearbox on full speed at 200 RPM, my reducing pulleys put the leadscrew at 90 RPM, plenty fast enough for most tasks. Sorry not to be of more help.
    DIYSwede has some good advise in his reply.
    Regards
    Alan
  10. The Following User Says Thank You to olderdan For This Useful Post:
    Paul Jones (Apr 22, 2020)
  11. #6
    Aug 2016
    France
    Hello, can you fixed, handwhell on the end of leadscrew; please?
    do you have a section?
    Download plans for lathes.
