Results 1 to 7 of 7
Thread: Eccentric grinder from angle grinder - video
    Eccentric grinder from angle grinder. By Master Sh. 5:09 video:
    Floradawg (Mar 31, 2022), NortonDommi (Mar 31, 2022), rlm98253 (Mar 30, 2022), swk (Mar 31, 2022)
    Aug 2012
    Australia
    desbromilow's Tools
    other than making the sanding disc "wiggle" I don't see what value this is adding - what am I missing?
    Jul 2018
    Flora, MS
    Floradawg's Tools
    I wish I had that vise.
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Quote Originally Posted by desbromilow View Post
    An oscillating sander is more efficient than a pure rotary one and is less likely to gouge soft work and leave a series of small swirl marks as compared to large semi-circles which is why they are used to cut paint. Also don't clog sandpaper as much as a rotary sander.
    Aug 2012
    Australia
    desbromilow's Tools
    Thanks NortonDommi, so it is just "wiggling " to create much smaller movements - and the why is what you said above about small swirls, and less clogging of the paper.
    It also utilizes more of the abrasive available, with the center, not building up a raised deposit. The semi-circles are about 3/8" diameter, instead of concentric scratches. Not as fine a finish, but much like lapping.
  8. #7
    Aug 2012
    Australia
    desbromilow's Tools
    Thanks!!! - makes sense - you can tell I don't do a lot of sanding, but I daresay that will change one day.
