Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: Edge finder / Centering tool
    Jul 2017
    Port Elizabet, SA
    garage nut's Tools
    As the desire to work more accurate becomes close on an obsession, the only point of reference I have is the edge, so for that reason I need some way of accurately finding the edge. Looked at making a "Wabler", but with my current skill sets that is not going to happen
    Still open question, anybody knows what it happening in that "Edge Finder" in the video?
  2. #12
    olderdan's Tools
    There are a lot of simple ways to find the edge of a part, put a dowel in the machine and bring it to the edge or to a feeler gauge and you now know how much to index.
    Stick a small piece of oiled cigarette paper to the edge and when the rotating tool flicks it away you are .001 or .0025mm from the edge, this is useful when using a drill or end mill. There are many other methods that time seems to have forgotten but I will post making a Wobbler from a pin chuck.
  3. The Following User Says Thank You to olderdan For This Useful Post:
    garage nut (Jan 2, 2018)
  4. #13
    Jul 2017
    Port Elizabet, SA
    garage nut's Tools
    The "Paper Flicker" sounds about the easiest and fastest. Saves time not having to change from the "Edge finder" to the real cutter.
  5. The Following User Says Thank You to garage nut For This Useful Post:
    olderdan (Jan 2, 2018)
  6. #14
    Supporting Member flyfr8rs's Avatar
    Mar 2016
    Alaska
    A quick google search "make an edge finder" explains all, including how to make it.....
  7. The Following User Says Thank You to flyfr8rs For This Useful Post:
    Scotty1 (May 8, 2023)
  8. #15
    Alan,
    Would I be correct in thinking that you meant .001" or .025mm.
  9. #16
    olderdan's Tools
    Alan,
    Would I be correct in thinking that you meant C.001" or .025mm.
    Correct I forgot the imperial " symbol.
  10. #17
    I was thinking more about the conversion " to mm.
  11. #18
    olderdan's Tools
    Yes I meant .001 inches or .025mm, I like the metric system but all my equiment is imperial and mostly second hand so I am stuck with it.
  12. #19
    Alan,
    That mirrors my situation too. I hate when I have to work with imperial but my micrometers etc are/were imperial. Over the past few years I have been requesting for Xmas and birthdays that I get metric mics. for presents, so now I have metric stuff in my most used sizes. My calipers were always dual standard.
    Edge finder / Centering tool-caliper.jpg Dual standard.
  13. #20
    Piros1
    Dittmer, MO
    Pretty simple like you said and a very handy idea. I will add one to my arsenal.
