Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: Elastic Cord Wrap Ends
    Elizabeth Greene's Tools
    This took a bit longer than planned; I had saved this in one of my kitchen sink "playground" projects and had to carve it out into its own file.
    All done, though.
    I've uploaded the Fusion F3D file for this model, .stl and .3mfs for 3d printing, and dimensioned images to https://github.com/ElizabethGreene/M...Elastic%20Clip
    None of the dimensions are critical. If I were going to make more of these, I'd make the inside slot 3mm instead of 2. It's a bit snug getting the hair tie to fit into it at initial assembly.
  2. The Following User Says Thank You to Elizabeth Greene For This Useful Post:
    Saltfever (Nov 10, 2024)
  3. #12
    Apr 2012
    NorCal
    Saltfever's Tools
    Quote Originally Posted by Elizabeth Greene View Post
    . . . I'd make the inside slot 3mm instead of 2. It's a bit snug getting the hair tie to fit into it at initial assembly.
    THANK YOU, Elizabeth. Wow, every kind of file I would ever need!
    You suggested to increase the slot to 3mm, however the sketch indicates it is already 9mm long x 4mm wide. (center distance of the arcs is 5mm + 2mm radius each side). Has the sketch already been changed or what am I missing? All the best.
  4. #13
    OOps, I must have fixed it in the drawing and don't remember. Magic!
  5. The Following User Says Thank You to Elizabeth Greene For This Useful Post:
    Saltfever (Nov 11, 2024)
