Results 1 to 4 of 4
Thread: Electronic diode tester
    Back in the 70s when I was starting to get involved with integrated circuits* I had a source of cheap scrapped electronic boards. I would buy them and desolder and reuse the components. Of course, this involved a lot of component testing (after all, the boards had been scrapped for a reason) and identification since components often had only manufacturer markings.
    When I saw a design for a diode polarity/condition tester in an electronics magazine, I set to work to make one immediately. This photo...
    shows the finished product housed in a plastic box. Inside the box is this circuit...
    The op amp is wired as a square wave oscillator whose output swings from almost full positive to full negative with respect to ground. If a good diode is connected with its cathode end attached to 'A' the left hand LED is forward biased and will light. If the cathode end is connected to 'B', the right hand LED will light. Judicious placement of the LEDs relative to the test contacts will allow the lighted LED to indicate either the cathode or anode of the diode under test. (My version is set to indicate the anode.)
    The device also indicates diode condition. If both LEDs light, the diode is shorted. If neither lights, the diode is open. In either case, discard it.
    Although overkill, it's also good for testing fuses. A good fuse lights both LEDs, an open one lights neither.
    Yes, there are many other ways to test diodes. But, if you have a bunch, this thing will relieve a lot of the tedium.
    * Integrated circuits were a huge boon for me. As an undergrad physics student, we had to take a one semester electronics course. It was electronics for people who were not going to become electronic engineers but still needed to build and, more importantly, understand test equipment for experiments. Needless to say, it was very basic. It might help you to understand how an op-amp works but you would never be able to build one based on what you had learned there.
    Integrated circuits changed all that. All of a sudden it was black box engineering. You didn't need to know what went on in the chip. Just hook modules together to obtain the desired effect. (Well, at least at the hobby level; for stuff that was going to fly we called in the EEs.)
  2. The Following 17 Users Say Thank You to mklotz For This Useful Post:
    baja (Aug 26, 2020), Duke_of_URL (Jan 11, 2024), emu roo (May 23, 2025), hegefer (Nov 8, 2018), Metallurg33 (Jan 10, 2024), n9dug (Aug 25, 2020), oldcaptainrusty (Jul 6, 2018), Paul Jones (Aug 26, 2020), rendoman (Jul 16, 2018), rgsparber (Jul 21, 2018), rlm98253 (Jul 6, 2018), rossbotics (Jul 7, 2018), Seedtick (Jul 6, 2018), Sleykin (Jul 7, 2018), trigger (Aug 25, 2020), volodar (Jul 7, 2018), wkp1950 (Jul 6, 2018)
    Thanks mklotz! We've added your Electronic Diode Tester to our Electronics category,
    Nov 2015
    Italy
    rendoman's Tools
    Nice!!
    I've never tried one, but it seems very useful!
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Marv,
    This isn't the first time one of your tools has inspired me to think of a different way to do the task. I figured out how to make a diode tester using 3 AAA batteries, a pushbutton, an ATTiny85 processor, one resistor, and two LEDs. The pushbutton applies power as long as it is pressed. When the ATTiny85 powers up, it will measure the voltage drop across the device under test sequentially applying both polarities of current. If it sees around 0.7V, the corresponding LED will light just like your design. If the drop is around 0.4V, the corresponding LED will flicker to say both which end has the cathode and that it is a Schottky. If a short is detected, both LEDs will light. If an open is present, it would slowly flash both LEDs alternately. Since all of this is in the software, the "manufacturing" cost is zero.
    This was just a thought experiment. I don't need to actually make one. My curve tracer works fine.
    Thanks for the fun mind exercise.
    Rick
    Rick
  6. The Following User Says Thank You to rgsparber For This Useful Post:
    Paul Jones (Jul 21, 2018)
