Results 1 to 7 of 7
Thread: Endmill Sharpening device, end cutting edges only
    Supporting Member Metaler's Avatar
    Mar 2013
    UK
    Metaler's Tools
    Sharpening an endmill has two quite different edges to sharpen. Those on the side which is difficult and need relatively complex equipment, and those on the end which are easy with quite simple tooling. Sharpening the end edges only is well worth doing as it will considerably improve the finish achieved when being used to surface a workpiece.
    The video which I am introduceing here shows a device for sharpening the end edges, being easy to use and easy to make in just a few hours.
    The pages on my website that relate to the device is here
    Harold Hall
  2. The Following 21 Users Say Thank You to Metaler For This Useful Post:
    57_210 (Jan 17, 2024), Andyt (Feb 5, 2020), asterix (Aug 21, 2022), bbutcher85 (Sep 28, 2016), Frank S (Sep 18, 2016), high-side (Feb 8, 2020), Home-PC (Aug 18, 2022), johncg (Dec 18, 2021), Jon (Sep 22, 2016), Kevic (May 12, 2018), martink (Sep 19, 2016), melchis (Jan 4, 2018), Okapi (Jun 29, 2017), olderdan (Jan 1, 2018), Paul Jones (Sep 19, 2016), PJs (Sep 28, 2016), Ralphxyz (Apr 18, 2023), Scotty12 (Feb 4, 2020), skypilot (Apr 8, 2019), Sleykin (May 14, 2018), Yaculls (Sep 30, 2016)
    martink's Avatar
    Jan 2016
    martink's Tools
    I can vouch for this being easy to make and use. I ruined a lot of cutters when I first got my little bench mill, but Harold's simple tool made a lot of them usable again. The grinding rest behind is also one of Harold's creations..
    Endmill Sharpening device, end cutting edges only-img_20160919_153636396.jpg
  4. The Following 3 Users Say Thank You to martink For This Useful Post:
    high-side (Feb 8, 2020), Paul Jones (Sep 19, 2016), PJs (Sep 28, 2016)
    Thanks Metaler! We've added your Endmill Edge Sharpening Fixture to our Sharpening category,
    as well as to your builder page: Metaler's Homemade Tools. Your receipt:
    Mr Magoo (Oct 2, 2016)
    Dec 2015
    bbutcher85's Tools
    Good job on instructions
    Good job on your detailed instructions. Far too many tools are submitted with only a photo and no information on how to build the tool or how to use it.
    Bob
    <div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-endmill-edge-sharpening-fixture"> <img src="/uploads/158177/homemade-endmill-edge-sharpening-fixture.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-endmill-edge-sharpening-fixture">Endmill Edge Sharpening Fixture</a> <span> by <a href="http://www.homemadetools.net/builder/Metaler">Metaler</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/sharpening'>sharpening</a>, <a href='http://www.homemadetools.net/tag/fixture'>fixture</a> </div> </div> </div> </div>
  8. The Following 2 Users Say Thank You to bbutcher85 For This Useful Post:
    elk-a-holic (Apr 17, 2023), Metaler (Nov 30, 2016)
    olderdan's Tools
    Thank you Harold for this very effective sharpening system. In my case I use it for the secondary only and the primary is done on my tiplap style grinder on a CBN wheel.
  10. The Following User Says Thank You to olderdan For This Useful Post:
    Paul Jones (Jan 1, 2018)
  11. #6
    Oct 2019
    Germany
    uv8452's Tools
    I copied Harold's design and I found it a joy to use. Easy and precise. I even made some 'chucks' out of hexagonal bars to grind 3-fluted endmills.
  12. #7
    Dec 2014
    Ingham Australia
    Excellent description and drawings
