Thread: ER-40 collet chuck for metal lathe.
    Feb 2013
    Salem Ohio
    aametalmaster's Tools
    Cool ER-40 collet chuck for metal lathe.
    Here is my ER-40 collet chuck i made for my SB 10K lathe. Its just a scrapbox steel bar threaded to fit the spindle and then the other end is threaded for a nut to hold the collet. The inside is taper turned to the collet angles as well as the inside of the nut end. I don't have plans just lots of building pics. I have lots of room so if the inside ever wears out i can recut the taper and freshen it up. Been using it for about 6 years with zero problems. The factory ER nuts have a ring to pop the collet free from the body as they do get tight gripping the part. I use an aluminum knocker bar thru my spindle to bump it free. Any ???? just ask...Bob
    Attached Thumbnails Attached Thumbnails ER-40 collet chuck for metal lathe.-5-threading-body-nose-cap.jpg   ER-40 collet chuck for metal lathe.-4-trying-collet.jpg   ER-40 collet chuck for metal lathe.-3-inside-taper-cut.jpg   ER-40 collet chuck for metal lathe.-2-chuck-body-threaded-spindle.jpg   ER-40 collet chuck for metal lathe.-1-chuck-body.jpg
  2. The Following 5 Users Say Thank You to aametalmaster For This Useful Post:
    dmaciel (Feb 22, 2013), Home-PC (Feb 22, 2020), Jon (Feb 18, 2013), kbalch (Feb 18, 2013), Paul Jones (Nov 15, 2014)
    Feb 2013
    Salem Ohio
    Cool Few more pics.
    Here are some more pics...Bob
    Attached Thumbnails Attached Thumbnails ER-40 collet chuck for metal lathe.-6-threaded-body-taper.jpg   ER-40 collet chuck for metal lathe.-7-boring-nose-hole-threading.jpg   ER-40 collet chuck for metal lathe.-8-nose-taper-cut-hole-bored.jpg   ER-40 collet chuck for metal lathe.-9-nose-threaded.jpg   ER-40 collet chuck for metal lathe.-10-collet-body-screwed-inside-nose.jpg
  4. The Following User Says Thank You to aametalmaster For This Useful Post:
    Feb 2013
    Salem Ohio
    Cool
    Some more...Bob
    Attached Thumbnails Attached Thumbnails ER-40 collet chuck for metal lathe.-11-done-but-needs-shaping.jpg   ER-40 collet chuck for metal lathe.-12-after-shaping-suit.jpg   ER-40 collet chuck for metal lathe.-735b%5B1%5D.jpg   ER-40 collet chuck for metal lathe.-9201%5B1%5D.jpg   ER-40 collet chuck for metal lathe.-milling-block1.jpg
  6. The Following 2 Users Say Thank You to aametalmaster For This Useful Post:
    Home-PC (Feb 22, 2020), Paul Jones (Oct 21, 2014)
    Thanks again aametalmaster! We put this one in our Lathes category, and of course on your homemade tools page: aametalmaster's Homemade Tools. Your receipt:
  8. The Following User Says Thank You to Jon For This Useful Post:
