Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Thread: EV Anvil (exhaust valve)
    Jan 2016
    Dubrovnik - Croatia
    LMMasterMariner's Tools
    Hi guys,
    Must say that anvils are very popular tools these days and here is mine, which I 'made' 35 or so years ago.
    Drilled hole in my great grandfather's workbench (which is by the way full of worms and more than 120 years old
    but it's made of oak and still solid.) and inserted exhaust valve from auxiliary engine of some small ship.
    Head diameter is 100 mm and that's more than good for all my hammering jobs.
    I don't make horseshoes, nor anything similar for which I need strange shaped anvil.
    Regards
    LMMasterMariner
    Attached Thumbnails Attached Thumbnails EV Anvil (exhaust valve)-20170620_122720.jpg   EV Anvil (exhaust valve)-20170620_122748.jpg
  2. The Following 21 Users Say Thank You to LMMasterMariner For This Useful Post:
    baja (May 1, 2020), benkeller3 (Feb 25, 2018), big dog (Mar 30, 2026), blkadder (Feb 24, 2018), Captn Roy (Jun 21, 2018), clydeman (Apr 30, 2020), DIYer (Jun 21, 2017), emu roo (Dec 16, 2025), gunsgt1863 (Jun 20, 2018), high-side (Apr 30, 2020), Mark Fogleman (Jun 21, 2017), mr95gst (Jun 21, 2017), n9dug (May 1, 2020), oldcaptainrusty (Jun 21, 2018), Paul Jones (Jun 21, 2017), rlm98253 (Feb 24, 2018), Scotsman Hosie (Mar 6, 2018), Seedtick (Jun 21, 2017), toma (Feb 25, 2018), Tuomas (Jun 23, 2017), volodar (Jun 21, 2018)
    Thanks LMMasterMariner! We've added your Anvil to our Anvils category,
    as well as to your builder page: LMMasterMariner's Homemade Tools. Your receipt:
    Supporting Member Ed ke6bnl's Avatar
    Mar 2012
    So. California high desert
    Ed ke6bnl's Tools
    not sure what is meant by an anvil, or is it just something to hammer on?
    1950 F1 street rod
    1949 F1 stock V8 flathead
    1948 F6 350 chevy/rest stock, no dump bed
    1953 chevy 3100 AD for 85 S10 frame going for a 4BT cummins motor, NV4500
    1968 Baha Bug with 2.2 ecotec motor, king coil-overs,P/S
    2000 National Sea Breeze 5th wheel trailer
    1998.5 Dodge 2500 4x4 Cummins,
  5. The Following User Says Thank You to Ed ke6bnl For This Useful Post:
    Ed. I'll offer an explanation which may be of use to others as well. Any hard object becomes an anvil when another object is placed or laid on it and struck with a 3rd object the 3rd object becomes a hammer regardless of shape or weight this is also true of an anvil. A person could place a nut on any surface then strike it with their fist the surface is the anvil and the fist is the hammer
    I often use the counter weight on my forklift as an anvil when I need a very large hard surface to assist in shaping sheet metal also I often use 2 hammers by holding 1 as a back up while striking with the other the back up hammer is at that instance an anvil.
    If the object being used as an anvil also has a particular shape that something is formed into over or around then it could be called a die as well
    LMMasterMariner's use of a large diameter exhaust valve is just one more example of the many things which can be utilized as beneficial simple tools readily at hand
  7. The Following 7 Users Say Thank You to Frank S For This Useful Post:
    baja (May 1, 2020), Beserkleyboy (Jun 20, 2018), Big Sexy (Apr 30, 2020), emu roo (Dec 16, 2025), gunsgt1863 (Jun 20, 2018), LMMasterMariner (Jun 21, 2017), Scotsman Hosie (Mar 6, 2018)
    Jan 2016
    Dubrovnik - Croatia
    Hi Frank,
    Many thanks for an excellent explanation.
    Regards
    LMMasterMariner
  9. The Following User Says Thank You to LMMasterMariner For This Useful Post:
  10. #6
    I'm going to go out on a limb here and speculate that the valve came from an engine that had 4 valves per cylinder and the pistons were at least 350 mm in diameter probably idled around 300 RPM and ran at no more than no more than 1000 RPM under full load I won't speculate on the number of cylinders since it could have been anything from an inline 6 cylinder to a 24 cylinder "V" type How far am I off?
  11. The Following User Says Thank You to Frank S For This Useful Post:
  12. #7
    Marion, Iowa
    metric_taper's Tools
    Gosh, what a lineage of tool life, and from a your Great-Grandfather.
    I see worm holes, but I don't see hammer marks on the bench, great way to protect this old surface and patina.
    Thanks for posting this.
  13. The Following 2 Users Say Thank You to metric_taper For This Useful Post:
    emu roo (Dec 16, 2025), LMMasterMariner (Jun 21, 2017)
  14. #8
    Jan 2016
    Dubrovnik - Croatia
    Hi Frank,
    I have no idea how big was that engine. I collected that valve from the vessel which I visited on her call to my home place 35 years ago. Can't even remember the name of the vessel so I can't find the details of the engine. Nowadays everything gets bigger and the main engine of my last vessel have 2 stroke main engine of 72240 kW. (@104 RPM). Exhaust valve of that engine would be little bit too big for anvil in my workshop. I could take discarded exhaust valve of aux. engine (4000 kW @720 RPM) from that vessel to replace my anvil, but already had enough weight in my luggage.
    Regards
    LMMasterMariner
  15. The Following User Says Thank You to LMMasterMariner For This Useful Post:
  16. #9
    Jan 2016
    Dubrovnik - Croatia
    Ed,
    I am just hobby machinist, not hobby blacksmith and this anvil served me well for the last 35 years.
    Material of that valve is excellent but still there are some marks on it.
    BTW, there are round bench anvils around. One of them can be found at Benchtop Anvil - Potter USA
    USD 95 but no longer available and mine one came for free.
    Regards
    LMMasterMariner
  17. The Following User Says Thank You to LMMasterMariner For This Useful Post:
  18. #10
    Jan 2016
    Dubrovnik - Croatia
    Hello metric_taper,
    Thanks for the comments. I can't remember that I have ever missed the anvil or work on the anvil. No hammer marks on the bench, but if you zoom in the picture, there are numerous marks done when cutting something on that bench. Some old paint on it also. Worm holes are still there but all worms were killed during fumigation. I have another work bench which is much younger but in worse condition than this old one.
    Regards
    LMMasterMariner
  19. The Following User Says Thank You to LMMasterMariner For This Useful Post:
