Results 1 to 9 of 9
Thread: Extreme trailer sway leads to crash - GIF
Hybrid View
    Oct 2016
    old kodger's Tools
    I note with interest that the vehicle taking the footage didn't stop to see if they could help with anything.
    Not my problem Jack, pull up the ladder.
  2. The Following 2 Users Say Thank You to old kodger For This Useful Post:
    IntheGroove (Sep 29, 2021), Toolmaker51 (Sep 29, 2021)
    Didn't stop, not even appearing to back off speed or veer one fraction in avoidance. The swerving truck didn't have much time to react, no evidence of brake lights or effort to slow and lessen fishtailing. It seems just a load of wood; I'll bet it's a tilt trailer, takes planning to get tongue weight. Uniform full length items will balance behind the axle, sway included free.
    I've only had one load act up, a 36" Moak Bandsaw, it must be over 8' tall, giant 5hp direct drive, table removed to ship, whole frame is cast iron. Estimating the center of gravity (to right side of axles) wasn't enough. Soon after entering highway, she started acting up. So, broke down the ratchet straps, and used them to pull load farther forward, with a tape measure to judge height of hitch.
    Needed more than a foot to get it right.
    Rest of the drive uneventful.
    Sep 2013
    Karl_H's Tools
    ... pull load farther forward, with a tape measure to judge height of hitch.
    What parameters did you use? I can see that the hitch higher than baseline (baseline being no trailer attached) would indicate that the load is too far behind the trailer axle; hitch way lower than baseline, the load is too far forward. Is there a spot where it is just right, or did you do a trial and error and use the height as an arbitrary increment?
    Feb 2018
    Quote Originally Posted by Karl_H View Post
    I load till I see tow vehicle go down a bit.
  6. The Following User Says Thank You to Tooler2 For This Useful Post:
    Karl_H (Nov 19, 2024)
