Results 1 to 8 of 8
Thread: Failed bearing melts housing - GIF
    May 2024
    emu roo (Jan 6, 2026), nova_robotics (Jan 7, 2026)
    Lake Tahoe
    IntheGroove's Tools
    That poor little zerk fitting...
  4. The Following 2 Users Say Thank You to IntheGroove For This Useful Post:
    emu roo (Jan 6, 2026), Frank S (Jan 5, 2026)
    Wonder why it is that people's first instinct seems to be to stand there for 10 seconds filming something which judging by the color of the shaft could be only seconds away from catastrophic failure, instead of hitting the emergency stop button that is most likely located on the front of that yellow box then start filming as the machine cycles to a stop.
  6. The Following 3 Users Say Thank You to Frank S For This Useful Post:
    emu roo (Jan 6, 2026), Karl_H (Jan 6, 2026), KustomsbyKent (Jan 6, 2026)
    Supporting Member bob_3000's Avatar
    Aug 2020
    I don't think ten seconds of filming is going to make any difference to that machine's situation.
  8. The Following User Says Thank You to bob_3000 For This Useful Post:
    Quote Originally Posted by bob_3000 View Post
    It would if the shaft were to break then there would be a lot more to worry about. As bad as the condition was right then as long as the shaft is not broken once it cooled and the bearing was removed the shaft could be built up and machined back to specs possibly without having to remove it with a portable journal lathe
    https://mm-source.com/strikertm-port...nal-lathe.html
    Not one like in the link but something like my portable boring bar set up except with a cutter facing inside mounted on a hollow cylinder index beringed from the undamaged portion of the shaft closer to the belt roller
  10. The Following User Says Thank You to Frank S For This Useful Post:
  11. #6
    Aug 2020
    It would it the shaft were to break then there would be a lot more to worry about.
    But it didn't.
  12. The Following User Says Thank You to bob_3000 For This Useful Post:
  13. #7
    But it didn't.
    No, it didn't but the videographer couldn't have known when it would. Perhaps that was their hopes. To video what happens when the shaft broke to increase their hit count. instead to attempting to prevent more damage costing the company a lot more money and down time.
    There is another scenario whoever was shooting the video may have alerted someone to shut the machine down and remained there videoing the failed bearing while a supervisor was initializing shut down. We can't know for sure there was an "E" button located on the face of the yellow box, but that is usually why boxes like that exist.
  14. #8
    Supporting Member thevillageinn's Avatar
    Jul 2017
    thevillageinn's Tools
    It’s a good question…Could be related to the working conditions or level of responsibility afforded to the person recording? Or maybe they hope to go viral and get their 15seconds of fame? Who knows
