Thanks for your support! From the start I knew that this machine isn't going to cut steel with 15mm endmills, the expectations are much lower. Unfortunately I do not have space for much bigger equipment, if I happen to own a bigger shop in the future I would like to invest in bigger (perhaps older) machines to do the real work. My goal is to achieve similar performance as, for example, a €1000 mini mill. Hopefully this machine will enable me to do work that can't be done without milling machines.
