Results 1 to 8 of 8
Thread: Fitting DRO to a Sieg SX2.7 Milling Machine
    Apr 2017
    UK
    editor@glue-it.com's Tools
    Part 1 - me looking at the parts and thinking about what goes where....
  2. The Following User Says Thank You to editor@glue-it.com For This Useful Post:
    nova_robotics (May 26, 2021)
    Apr 2017
    UK
    Now me installing the z-axis:
    and mounting the display....
  4. The Following User Says Thank You to editor@glue-it.com For This Useful Post:
    Apr 2017
    UK
    Specifications and some additional images of the installation of the kit: Sieg SX2.7 DRO Installation
    I will run some further tests on each axis and plot the comparisons.
    Plus, you may have heard in the video me talking about increasing the column stiffness. I'm ordering some parts today and this will be my next modification to improving this mill.
    Apr 2017
    UK
    Finally I have finished the installation, now I have a DRO that reads down to 0.005mm in X, Y and Z - and I can switch to imperial at the touch of a button
    I now need to get back to making models, hopefully now with more accuracy on the milling machine
    Thanks editor@glue-it.com! We've added your X and Y Axis Encoder Installation to our CNC category,
    as well as to your builder page: editor@glue-it.com's Homemade Tools. Your receipt:
    Apr 2017
    UK
    Whilst fitting the DRO you will have seen that I created a space between the column and the power supply case.
    Enough space for a bracket.
    And so I created a Sieg SX2.7 stiffening bracket
    This has increased the static stiffness by 1.5x
  9. #7
    Apr 2017
    UK
    and yet another video....
  10. #8
    Apr 2017
    UK
    Mill Stiffness = Top Finish is definitely true, I made this end mill cut on 2 off 1/4" thick mild steel plates bolted together. I can feel that the vibration on the column is significantly reduced with the bracket fitted and when making this type of cut.
