Results 1 to 5 of 5
Thread: Flat sanding cawl
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Flat sanding cawl
    In luthery work, for the purpose of leveling the frets of a fingerboard, you need a dead flat sanding cawl.
    Here is how to make one out of wood and glass.
    I first shape a wooden handle block, planned as flat as possible.
    Then I cut with a standard glass cutter three layers of the same size out of a scrap piece of window glass, maybe 3mm thick.
    All these, glued together using CA glue (works very well on glass)
    After the glue has cured, the edges are smoothed using a dremel and a diamond wheel.
    Eventually, I have stuck a sheet of 1000 grit sandpaper using double side tape.
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 4 Users Say Thank You to Christophe Mineau For This Useful Post:
    candsgrandmaster (Mar 26, 2020), FEM2008 (Mar 26, 2020), HobieDave (Mar 26, 2020), Jon (Jul 5, 2020)
    Thanks Christophe Mineau! We've added your Flat Sanding Caul to our Luthiery category,
    as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
    JoeH's Avatar
    Mar 2018
    Very cool, Christophe. This is something I can use in my guitar making and repair work. I note your wooden pattern makers vise in the photo.
  5. The Following User Says Thank You to JoeH For This Useful Post:
    Christophe Mineau (Mar 27, 2020)
    Jul 2014
    France, Brittany !
    Thanks Joe. Yes, I think I have showed already this one, yes it's here :
    A wooden vise for instrument making
    I like this vise, and the wooden build doesn't make it less usable than the cast iron version. It's been maybe 12 years I have built it I think, still in use.
    Maybe , sooner or later I'll have to redo the handle of the crank witch pivot is maybe too far backward from the bearing that supports the screw.
    Cheers !
    Christophe
    Perth Ontario Canada
    Laminated glass! Nice touch. I made something like this 30 years ago when i started doing piano gloss black type finishing. It is a very effective way to make a flat area very flat!
  8. The Following User Says Thank You to mwmkravchenko For This Useful Post:
