Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Float Lock Vise
    Jan 2018
    Dbj58's Tools
    Float Lock Vise
    I have a regular small size benchtop drill press and I have tried a number of vises but I was not really happy. I saw Mr Pete demonstrating a float lock vise on youtube he bought at an auction, it seemed quite big for my little drill press so I decided to make my own to match the table size.
    The jaws are from 3/4" square mild steel x 3" long. I used 8mm rod and cut a 8 x 1.25mm thread for the screw. For the shaft I used a 8mm hardened shaft from a printer. The other parts are all from mild steel.
    Here is a video of it
    https://drive.google.com/file/d/1-wE...ew?usp=sharing
  2. The Following 27 Users Say Thank You to Dbj58 For This Useful Post:
    baja (Aug 7, 2019), bruce.desertrat (Aug 6, 2019), Catfish (Aug 9, 2019), Christophe Mineau (Apr 3, 2023), cogentia (Jul 1, 2023), emu roo (Jul 23, 2024), Harvey Melvin Richards (Aug 6, 2019), high-side (Aug 7, 2019), HUMARIA (Aug 6, 2019), jackhoying (Aug 6, 2019), Jon (Aug 6, 2019), lassab999 (Nov 19, 2022), Miloslav (Aug 6, 2019), mr mikey (Mar 26, 2024), mrsuwds (Apr 23, 2020), mwmkravchenko (Apr 26, 2022), nova_robotics (Apr 26, 2022), Resident114 (Apr 26, 2022), Retro Steam Tech (Aug 7, 2019), Seedtick (Aug 6, 2019), Sleykin (Aug 10, 2019), sossol (Aug 7, 2019), threesixesinarow (Aug 6, 2019), Toolmaker51 (Aug 10, 2019), trevor_60_r (Jul 28, 2024), Tule (Aug 9, 2019)
    bruce.desertrat's Tools
    That's very nice; might it be possible to get higher-res versions of those pictures? (or at least the second one)
  4. The Following 3 Users Say Thank You to bruce.desertrat For This Useful Post:
    Resident114 (Apr 26, 2022), Sleykin (Aug 10, 2019)
    Thanks Dbj58! We've added your Float Lock Vise to our Vises category,
    as well as to your builder page: Dbj58's Homemade Tools. Your receipt:
    Jan 2018
    petertha's Tools
    I like it! Can you clarify what I think I'm seeing?
    - red arrow = vise block tapped to match threaded rod?
    - orange arrow = dowel pin through the slider rod to retain it?
    - green arrow = ? looks like a pin but off to the side? I would think the vise block has a ID slightly over the thread rod OD? Can you elaborate on this or show the parts disassembled? Or a sketch?
    Jan 2018
    Dbj58's Tools
    bruce.desertrat,
    Thank you, here is a link to my google drive where all the photos are. If you want dimensions I can do you a rough drawing for you.
    https://drive.google.com/drive/folde...pl?usp=sharing
  8. The Following 3 Users Say Thank You to Dbj58 For This Useful Post:
    bruce.desertrat (Aug 7, 2019), Jon (Aug 8, 2019), Resident114 (Apr 26, 2022)
    Jan 2018
    Dbj58's Tools
    petertha,
    you are correct the moving jaw is tapped to take the screw (red arrow), the yellow arrow is a retaining pin for the rod there is one on the other end as well to secure the bottom, the green arrow is also a retaining pin for the screw and you are correct about placement. It is a 2mm pin and it is drilled at 4mm from center on an 8mm hole, I cut a groove in the screw that it slides into. I have a picture on my google drive showing the pin, offset and screw thread groove. Here is the link
  10. The Following User Says Thank You to Dbj58 For This Useful Post:
  11. #7
    Supporting Member Catfish's Avatar
    Oct 2013
    Mariposa, California
    Catfish's Tools
    Very nice.
    Visit me on You Tube for many tool making videos.
    Link: https://www.youtube.com/user/Catfish6945
  12. #8
    Thanks a lot. The more I think about this the more I see how useful it is; I have a dinky 8" HF benchtop drill press; I've picked up a couple conventional small drill pres vises, but being able to adjust it so freely and lock the work in place like this looks to be very useful.
  13. The Following User Says Thank You to bruce.desertrat For This Useful Post:
    Canyonman44 (Nov 28, 2024)
  14. #9
    JoeH's Avatar
    Mar 2018
    Can't thank you enough for posting about this. This is great. I had no idea these things exist and it looks pretty straightforward to build. I hunted up Mr. Pete's video on his old vise on youtube. Thanks again.
    I have been using a bolt stuck into the drill press table to keep the drill press vise from rotating. It helps. But this float lock would be better.
  15. #10
    For others wanting to find it, here's Mr. Pete's video.
  16. The Following 3 Users Say Thank You to bruce.desertrat For This Useful Post:
    cognitdiss (Mar 26, 2024), Jon (Aug 9, 2019), olderdan (Aug 9, 2019)
