Results 1 to 10 of 16
Thread: Fly Cutter Attachment for Lathe Faceplate
Hybrid View
    Sep 2012
    Hinchinbrook QLD
    Toughness maybe. Or hardness.
    Depending on the stiffness of the steel
    But Youngs modulus tells us that pretty much all steels are pretty much the same "stiffness"
  2. The Following User Says Thank You to 12bolts For This Useful Post:
    Captainleeward (Dec 1, 2017)
    Quote Originally Posted by 12bolts View Post
    Toughness maybe. Or hardness.But Youngs modulus tells us that pretty much all steels are pretty much the same "stiffness"
    True, but I was referring to the stiffness of the shape, not the material. Since I used a C-section, I was concerned about it deflecting while cutting. A stiffer shape would be better.
    I probably should have worded it more clearly.
  4. The Following 2 Users Say Thank You to mklotz For This Useful Post:
    Captainleeward (Dec 1, 2017), Paul Jones (Dec 8, 2017)
