Results 1 to 10 of 15
Thread: Fly Cutter with R8 arbor for the mill..Plans available by Rossbotics.
    jjr2001's Tools
    Thanks Doug, this is a great one!
    I wanted to make this one when I first put eyes on it. This works out to be the best fly cutter
    I have. Two others in my quiver are either too big or too light for my mini mill. Anyhow you can
    get the prints from HMT via this link:
    http://www.homemadetools.net/forum/f...9585#post27581
    I used hot rolled steel that I had on hand. It was 1 3/8" in diameter so just a bit smaller
    than the 1.5" speced. Followed the plans and this one is now my best fly cutter.
    Cheers, JR
    Attached Thumbnails Attached Thumbnails Fly Cutter with R8 arbor for the mill..Plans available by Rossbotics.-img_2233.jpg   Fly Cutter with R8 arbor for the mill..Plans available by Rossbotics.-img_2232.jpg   Fly Cutter with R8 arbor for the mill..Plans available by Rossbotics.-img_2231.jpg   Fly Cutter with R8 arbor for the mill..Plans available by Rossbotics.-img_2234.jpg   Fly Cutter with R8 arbor for the mill..Plans available by Rossbotics.-img_2237.jpg
    Fly Cutter with R8 arbor for the mill..Plans available by Rossbotics.-img_2238.jpg   Fly Cutter with R8 arbor for the mill..Plans available by Rossbotics.-img_2239.jpg
  2. The Following 13 Users Say Thank You to jjr2001 For This Useful Post:
    Andyt (May 1, 2019), emu roo (Jun 26, 2025), high-side (Dec 31, 2018), mwmkravchenko (Dec 28, 2018), Okapi (Dec 29, 2018), Paul Jones (Dec 28, 2018), PJs (Dec 30, 2018), rossbotics (Dec 28, 2018), Scotsman Hosie (May 1, 2019), Seedtick (Dec 28, 2018), Toolmaker51 (Dec 28, 2018), Tule (Dec 29, 2018), UncleBob (Dec 28, 2018)
    Dec 2013
    Florida
    rossbotics's Tools
    That came out nice JR. it does leave a nice finish and you can run it at a pretty high RPM ! I did find another use for it other than just a fly cutter, it did a great job on creating a grip pattern on the new vise jaws I made for my bench vise too.
    Thanks for posting your completed project. click the photo to enlarge Fly Cutter with R8 arbor for the mill..Plans available by Rossbotics.-2.jpg
    Doug
    Comments are always welcome
    Doug
  4. The Following 6 Users Say Thank You to rossbotics For This Useful Post:
    Alan Purdy (Mar 16, 2019), emu roo (Jun 26, 2025), jjr2001 (Dec 28, 2018), PJs (Dec 30, 2018), Scotsman Hosie (May 1, 2019), Toolmaker51 (Mar 17, 2019)
    jjr2001's Tools
    Thanks Doug, I never would have thought of using the fly cutter for that pattern.
    If you had not posted how it was done I would have thought hours were expended
    with a rotary table and end mill! Your method would be so fast in comparison.
    Cheers, JR
  6. The Following User Says Thank You to jjr2001 For This Useful Post:
    Perth Ontario Canada
    Just goes to show us that age old ideas have their place. And it's nigh near impossible To match the finish you achieve with a fly cutter with anything else. Plus the tooling is way less expensive.
  8. The Following 5 Users Say Thank You to mwmkravchenko For This Useful Post:
    jjr2001's Tools
    Thank You mwmkravchenko, it was an interesting tool to make. The overall speed
    is quite good when surfacing with one.
    Cheers, JR
  10. The Following User Says Thank You to jjr2001 For This Useful Post:
  11. #6
    Aug 2016
    wizard69's Tools
    Nice fly cutter there. I can see where having a set of these in various diameters would be nice. I have to believe that this is a better balanced solution than some fly cutter designs.
  12. The Following 2 Users Say Thank You to wizard69 For This Useful Post:
    emu roo (Jun 26, 2025), jjr2001 (Dec 29, 2018)
  13. #7
    Thanks jjr2001! We've added your Fly Cutter to our Fly Cutters category,
  14. The Following User Says Thank You to DIYer For This Useful Post:
  15. #8
    Nice work! When you post a tool you made from homemadetools.net plans, you get another set of plans of your choice for free. Let me know which ones you want and I'll get them sent over to you.
  16. The Following User Says Thank You to Jon For This Useful Post:
  17. #9
    jjr2001's Tools
    Thanks Jon, I think I would like to try Rossbotic's nice tool post grinder. Might take me a while to build that one.
    Cheers, JR
  18. The Following User Says Thank You to jjr2001 For This Useful Post:
    PJs (Dec 30, 2018)
  19. #10
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Nice build JR...man the finish with that is spectacular! Looks like you nailed the grind and speeds on that. Also a mighty fine finish on that hot roll and the keyway on the R8!
    Great to see and hear how much of a value Doug's designs are and the versatility of scales/adaptability.
    Hat Tip and a Nod, JR!
    Mark Twain
  20. The Following User Says Thank You to PJs For This Useful Post:
    jjr2001 (Dec 31, 2018)
